Valve (clearance and timing) and ignition timing are the first places I'd look.
Run all your valves, but double check the exhaust valves. Too little clearance and they'll pop open early and you'll have flames up the head, even if the cam is timed up properly to the crank.
How does it run at idle? At speed and under load? If the ignition is retarded too far, the gas will still be burning when the properly timed and set exhaust valves open, again making for burning fuel in the head.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
