Magnetos are actually pretty reliable. There's a reason piston aircraft use them, though admittedly they do double up on them and everyting else in the egnition.
The H4 on the SuperA was a time tested and reliable mag, as well.
Only drawback I can think of is that on those rare occasions that somethng does go wrong there are things to a mag that not just everybody can fix, where a battery ignition distributor is pretty much a mechanical affair.
The big advantage to a mag is that you're not hostage to any of the things that can go wrong with a battery ignition (generator, cutout/VR, bad battery, a short anywhere, leaving the lights on . . . coil -- a mag has a coil, but it's not prone to the same kind of failure as the oil-filled cylidrical coils on the battery igntions). A magneto ignition won't die for any of those things going wrong and if you've got a hand crank you can start it and run it all day.
A little more difficult sometimes to fix, but less likely to fail and/or strand you is my view of a mag.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
