Just to add my comments, make sure the float is nice and fat, a lot of them get compressed over the years from some one appling air pressure to carb. And like it has been said before on this forum, a lot of the new seats are not nice and round and will not seal. You can't use the viton tip needle to form them so you need a suitable tool to do the job, I use a pintle from an injection nozzle tip. A good sealing needle and seat will hold the tip of your tongue if you invert the carb and suck on the inlet fitting. If it don't hold it will leak. Float setting is 1 27/32 inch , and make sure pivot pin is free in float and pinched in hinge with no excessive side play . Gasket on nozzle can also cause carb to leak , but usually slowly. Have fun.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
