The hoses goto your joystick valve. One is pressure the other is return. The piece that the hoses go into is the power beyond plate. Thats the part you need and it bolts to the left remote hydraulic valve under the seat. You will need a straight thru valve not the end type valve your tractor most likely has now. You will also need to cut a hole thru the left cast seat support for the hoses. One other option is to connect to one of your rear remotes and tie the lever in one position. That would have oil flowing thru your joystick valve at all times. One draw back is you lose the use of one remote for other purposes.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
