Posted by NawlensGator on August 19, 2009 at 08:17:35 from (52.129.8.50):
In Reply to: 140 governor issues posted by Chris Bridgers on August 18, 2009 at 18:33:58:
I fixed the governor on one of my 140's but I can't remember what I did (sorry, long ago).
You don't need to polarize the alternator. If it's a one wire set up you have to rev the engine higher to get it to charge. Also check out the amp meter and output voltage (about 14.5 volts is normal). May need a new alt.
The coil gets warm but not too hot to touch. If it's bad it will get really hot and eventually shut down the engine within an hour (after spitting and sputtering).
I had trouble recently with a sputtering 140 engine and found sparks were jumping all over from the SP wires (when viewed at night). Replaced the wires and all was well. Just a thought.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
