Rear Axel Drive Gear. (70 Teeth)
Posted by thebigron on August 22, 2009 at 19:51:07 from (75.143.162.5):
I have been going thru a 48 Cub the last couple of weeks, after finally getting her to run. Had some water in the steering gear box and transmission, so I felt like I had to check the final drive oil reserve. Fortunately both sides seem to be perfectly sealed for the last 60+ years. Only have a bit of sludge in the bottom, and it seems not to stick to a magnet. (It has been stored outside for a few years). I have inspected the drive gear closely and declare it to be no more than 1/10 of 1 percent wore out. It could last another 300 years before it will need to be checked. This baby is built to last. It could run for years with the oil drained. Has anyone ever had this gear to go bad on them?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
