Re: Farmall 300 front end wobble
Posted by Andy Martin on August 25, 2009 at 13:02:12 from (199.197.2.145):
In Reply to: Farmall 300 front end wobble posted by boatsmn on August 24, 2009 at 20:38:38:
In addition to worn gears, it can also be a worn lower bolster bearing. Jack up the front and see if you can move the wheels side to side.
A temporary fix is to lower the air pressure in one of the tires. That makes it pull enough to one side that you avoid most of the wobble.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
