Posted by Datractorman1 on August 26, 2009 at 23:04:54 from (205.188.116.73):
I'm thinking of buying a 784. I have found one in the $3500.00 range. The tractor has been well used,slightly abused and needs some money spent on it. The tach doesn't work so no idea of the hours. I would guess around 8-10 thousand. I plan to use it for bush hogging and rough work so I'm not intrested in cosmetics. The engine runs out good with no smoke,leaks,etc although it did seem a bit sluggish. It has problems with the brakes and parking brakes that seem to be common with this series and I'm figuring on replacing the clutch. I noticed something odd with the clutch. It seemed to be slow on take off when starting in the higher gears and gain speed after traveling a few feet. It didn't feel like a typical clutch slip. It felt to me more like a T/A tractor taking off in low range and switching into high. The guy told me he'd been pulling a disk with it and hadn't had any clutch slipping problems. I looked but didn't see any T/A linkage or any sign that it had a disabled T/A. Has anyone experienced anything like this? Also,is it possible to install a T/A in a non T/A tractor while replacing the clutch? Any info and feedback will be greatlt appreciated Thanks, David
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
