Posted by PurdueAg on September 01, 2009 at 09:57:39 from (198.109.220.6):
My 1950 C Farmall does not have the "DC/1-4" timing mark on the flywheel. I cleaned it and inspected it thoroughly and can't find the mark. I want to time the battery ignition unit to the engine. Not sure if TDC of Piston #1 is the exact timing position. I have the head off. Is TDC when the #1 piston is all the way up (I was thinking TDC was when the piston was furthest from the crankshaft, so I was thinking that would mean all the way up and level with top of block)? If so, should I position the piston that way, install the battery ignition unit, and then do a spark test as indicated in the manual? Can I do the spark test with the head off? Any help would be greatly appreciated.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
