Re: Delayed 2 point response
Posted by pete 23 on September 05, 2009 at 19:13:34 from (173.87.8.73):
In Reply to: Delayed 2 point response posted by CVM on September 05, 2009 at 14:36:12:
Your problem is in the unloading valve circuit. Probably a little contamination in the orfice in the unloading piston or bad o-ring. You can verify that unloading valve is problem by positioning hitch lever and then immediately dead head one of the loader valves, like have bucket fully up and pulling lever to try to pull it further. If hitch responds immediately you know where to look. Look at the parts layout on CaseIH site to locate valve if you don't have the manuals.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
