Posted by Melvin Ware on September 11, 2009 at 11:24:42 from (4.152.108.73):
I'm still trying to loosen the water pump pulley on my Farmall M in order to replace the generator belt. I have the locknut and set-screw out but can't get the pulley to budge. Have soaked the threads with plenty of PB blaster and hammered against the pulley "hump" using a rectangular stick of oak. (Still looking for a brass rod but no luck yet.) On closer examination, I noticed the two sides on the "hump" are not square as I first thought, but angled in toward the shaft. It's the same on both sides and appears symetrical. Is the pulley made this way and for what reason or did maybe a previous owner knock the corners off while loosening and tightening the pulley? The angle makes it hard to hold anything the hump to give it a decent lick. Any thoughts or suggestions?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
