Re: How do I tell if I have a 12 volt Generator
Posted by Janicholson on September 12, 2009 at 14:37:57 from (64.61.211.142):
In Reply to: How do I tell if I have a 12 volt Generator posted by Tom Fleming on September 12, 2009 at 14:11:25:
The ID tag on 12 volt generators were originally red in color. 6v were black. 6v can be converted to 12v. at a gen shop.
If it is charging now, it is probably a 12v.
If it is not charging, do the following test. Charge the battery till fully charged.
With it stopped/off. Jump the F terminal of the generator (small terminal) to a good shiny ground.
(does not need to be disconnected from reg)
Put a volt meter on the battery (across the bat posts) then start it up. At 3/4 throttle it should be making in excess of 14 volts Probably 15 or more. (an analog (needle) style meter is preferred) This is OK for several minutes.
If it is it is 12v gen. If it is like 13 volts it might be a 6v with a 12v regulator. JimN
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
