Posted by glennster on September 20, 2009 at 07:06:53 from (24.14.63.246):
In Reply to: M Farmall question posted by Jerry RV on September 20, 2009 at 07:02:22:
the fill plug for the rear end/trans is right by the base of the shifter. you need a 3/4 drive to fit in the plug to unscrew it. a 1/2 inch to 3/4 adapter works if you dont ahve a 3/4 drive set. on the left side of the tractor kinda by the clutch pedal and brake housing is a small square heas pipe plug. that is the sight hole to see if the trans is full. the belly pump holds about 6 qts of either 30 wt motor oil, or, i run hy-tran in my pumps. the belly pump is seperate.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
