Posted by Gmercer on September 26, 2009 at 15:43:40 from (24.230.119.203):
I'm trying to replace a leaking oil seal on the PTO shaft on my 1941 M Farmall. I've removed the shaft assembly from the rear. Ive removed the shift fork and related parts. I,ve removed the outer tube from the shaft. the only things left are the shaft and the housing. When I try to slide the shaft out of the housing, in either direction, it hits something solid and won't go any farther. I don't want to force it without checking with you guys first. How do I get the shaft out of the housing so I can replace the seal? Thanks for all your help. Gmercer, Spearfish, SD
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
