Re: ih 1066
Posted by Chuck's Repair on October 02, 2009 at 17:53:22 from (162.40.106.144):
In Reply to: ih 1066 posted by marceaux on October 02, 2009 at 06:56:21:
The pump timing mark and pointer can be seen by removing the pipe plug to the left of the injection pump. The engine timing mark and pointer can be seen by removeing the cover plate on the right side of the clutch housing. When the pump timing mark and pointer are lined up look at the timing marks on the flywheel to see what degrees your pump is timed at.
There is internal timing inside the pump that can only be adjusted with special tools and that timing can change by normal wear. If you are looking for accurate timing both internal and external timing need to be checked.
Chuck
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
