Posted by jimb2 on October 06, 2009 at 20:31:59 from (99.240.236.11):
In Reply to: IH 584 Brakes posted by Craig NC on October 06, 2009 at 12:42:35:
Hi Craig, are you talking about foot brakes or parking brake? Replacing the seals or disk for foot brakes requires removing the axles. So before removing the axles check all the brake lines for leaks etc. The brake lines run from the master cylinders under the battery box along the top of the transmission casting under the sheet metal cover and into the rear end under the seat. Search achives for 454,484,584,574,674,684 and you will find several references to brakes, bleeding etc.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
