Re: Cannot remove real wheel on 15-30 (22-36)
Posted by w400 on October 10, 2009 at 23:51:09 from (195.93.21.97):
In Reply to: Cannot remove real wheel on 15-30 (22-36) posted by Tom in Iowa City on October 10, 2009 at 15:52:59:
Good question to ask here which is stronger rust or C02 welder i had a leaking oil seal on SWD6 half shaft ended up removing bull gear and oilseal/bearing retainer and pulling entire shaft removed wheel rim and got entire center into hydralic press at 60 tons we chickened out was afraid it would break wheel center put it in a bath off old diesel for 2 weeks back into press and it started to move at only 20 tons pressure. dont you just love old iron
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
