A couple of places to look. On a C, it's most likely on the left side tapped into the lower inlet casting, between the hose and the block. If by chance you have a water pump in place of the regular inlet, it might still be in the same place.
The other would be on the upper neck which is also your fan support. In that position, the lead usually ran back the right side of the head, under the plugs.
You'll be looking for either a snipped off lead sticking out of a compression fitting, or a 1/8" pipe plug that might have been put in its place. Then it's always possible that someone replaced one of those pieces with one that was not tapped out for the probe. In that case you might find a boss in the casting that could be tapped out for the probe.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
