IT is the same as a 10SI Delco The S terminal is = to the #2 terminal on the Delco, and the I terminal is the same as the #1. S for sensor, I for indicator light. Connect S to the big stud terminal, and the I to a diode, or 10 to 20 ohm 10 watt resistor, or a bulb type marker or instrument light. The other terminal of the diode/resistor/lamp goes to the coil side of the ignition switch. JimN
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
