Posted by Mike CA on October 25, 2009 at 14:54:50 from (99.28.152.102):
Upon suggestion from this thread: http://ytforums.ytmag.com/viewtopic.php?t=548514 I turned the bracket upside down to see how that will affect my genny belt replacement. Here is what I found, please offer suggestions...
The bottom bracket, as you may know, has it's holes off-set. So when I flipped it, it pulled the genny back. That pulled the belt out of alignment, as shown here:
The flipped bracket also raised the genny, which put the belt very, very close to the bottom of the water pump, as seen in these 2 pics:
With the bracket flipped back, how I originally intended, you can see the clearance under the hood. But if I stretch it out to tension the belt, I get awfully close to the side of the hood. It may even hit. Hard to tell without the radiator on.
So, I'm not sure what to do. Buying a new belt may be expensive. I could drill out new holes in the bottom bracket to pull the genny forward to align it with the engine pulley, but I don't know if it will clear that water pump enough. I can only hope that it does.
What do you all think I should do at this point?
Oh, and a question was asked whether my genny pulley is adjustable... yes it is. When I tighten it, the slot for the belt has a larger diameter, tightening the belt.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
