As CNKS said, just snug, but not tight enough to start distorting the gasket. If you see the gasket starting to bulge around the bolts you've gone a hair tight. Also you want to do one bolt on each side, kind of like torqueing a wheel down.
As to your stripped bolt, the only way to replace that aluminium piece is to split the tractor. So your easiest option is to repair the hole with a helicoil kit. You can probably find one at any decent auto parts place. Basically what you'll do is drill the hole out larger, tap it, and install a special insert that will restore the threads to their original dimension.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
