Re: attaching front wheel weights to Farmall M wide-front
Posted by Randy in NE on October 27, 2009 at 04:43:12 from (204.124.192.32):
In Reply to: attaching front wheel weights to Farmall M wide-front posted by Stevie J. Mote on October 26, 2009 at 19:39:51:
It will take three 1/2 x 2 inch bolts per side. There are probably only three holes in the front hub that will line up. With the wide front you will be able to reach around the inside with a big screw driver to hold the bolt from turning as you tighten them. It would be up to you if you wanted to use regular bolts or grade 5. Grade 5 would probably be overkill for 42 1/2 lb weights.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
