Posted by pete 23 on October 27, 2009 at 10:35:14 from (173.87.147.73):
In Reply to: farmall m throttle ? posted by Kelly baldwin on October 25, 2009 at 05:59:48:
The plastic portion on the throttle shaft is something that will fit kits use as it was never original equipment. I don't really know if CASEIH uses plastic now or not. If governor linkage to carb is adjusted properly it will not hammer that against the stop every time governor goes to wide open throttle valve position.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
