Re: 100 - ammeter not registering correctly is VR bad ?
Posted by Janicholson on October 30, 2009 at 18:43:51 from (64.61.211.1):
In Reply to: 100 - ammeter not registering correctly is VR bad ? posted by couv on October 30, 2009 at 16:26:46:
Many gauges read a little off of Zero, so that is not a biggie if true.
Remove the negative battery cable and look at the gauge. If it stays in the same location, the needle is just a bit off. No problem there.
It should move farther to the left when the switch is turned on. Correct (as you indicate)
But the needle should move to the right when it is running (it will need to be at 3/4 throttle or full throttle to start the generator charging, then it should show charge. (usually about 8 to 10 amps for a while then tapering off to a bit above zero (or zero in your case)
Lets first polarize the generator.
With the battery connected, and the engine not running, use a stiff copper wire to bridge for one second, between the Gen terminal on the regulator (wire goes to the bigger generator terminal), and the Bat terminal on the regulator. This should make a nice spark (not dangerous).
Now the field poles are magnetized, and ready for charging.
Start it and see if it charges now. It might!
If not, make sure the gen and regulator have very shiny good grounds to the engine. Try it again!
If nothing, start it and set to 3/4 throttle. Use the above piece of wire to ground the F terminal of the generator o the engine. This will not hurt anything. If it now charges on the gauge, the regulator is probably bad. If it does not charge, take another piece of wire and (while it is running at 3/4 throttle, and the field is grounded as above, jump the Bat and Gen terminals (like you were polarizing, but with it running) If it now charges the regulator is bad. If it does not the generator should be tested at a reliable auto electric store. Many NAPA and other stores will do it free. Good luck, JimN
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
