i jack teh front wheels so they are about an inch off the ground, then use a 2 jaw puller on the bolster. there is a little bit of a flare there to get a grip on, back the nut off, then snug up the puller and strike the center bolt on the puller with a hammer. that is usually enough to get the gear to pop. when the gear is off, the shaft will drop right out the bottom if the front axle is off, so be careful, its heavy.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
