Posted by Wardner on November 11, 2009 at 08:47:36 from (4.154.247.58):
I'd like to get at least another pair of these. There is no part number. Only a date code of 8 June 1954. These were installed on my W-400. Weight seems heavier than a row crop weight.
Measurements are:
5" center hole
10.625" bolt circle
16" outside diameter
Will a Farmall A weight bolt up? If so, did the later 100-140 use this weight as a replacement for the earlier weight. If the dimensions are the same, the difference would be that the W-400 weight is stackable.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
