YOU WILL NEED TWO 5 1/2 INCH LONG 1/4 INCH FINE THREAD BOLTS A FINE THREAD BOTTOMING TAP TO CLEAN THE HOLES FOR THE PULLER BOLTS AND A STEERING WHEEL PULLER . A 1 1/8 th scoket and a Long breaker bar , and impact would work far better to remove the nut . You are going to ask why such long bolts , well with most steering wheel pullers you can ot get both puller bolts into the holes in the wheel as they are closer then anything out there . So you have to sorta make the bolts flex a bit so longer is better . and like Pete said a good pair of snap ring pliers and once the steering wheel os off ya remove the snap ring and set the steering wheel back on and give a sharp har turn either way and that old seal will just pop wirht out and i use a deep well socket to install the new one and in a matter of lets say 30 min you should be done . I can do them in ten min. but i have replaced many and i know what i need to carry to the job . It ain't hard to do and if ya run into trouble ya know where Pete and i are for help
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
