Posted by Red Dave on November 17, 2009 at 08:16:42 from (66.216.141.163):
In Reply to: Electrical experts? posted by Dave H (MI) on November 17, 2009 at 07:53:46:
Short answer is yes. But there are a few caveats. The meter works by putting the coil of the meter movement within the magnetic field of the current flowing in the conductor. That flowing current then induces a small current in the meter movment to make it deflect and give a reading. I have one like it, and it works very nicely to tell the direction of current flow and approximetely how many amps are flowing. It is not a pinpoint precision device, but is reasonably accurate as long as you understand it's limitations.
Yes, you can set up a circut on the bench to test it. If it is like mine, it may take more than a lamp to draw enough current for the meter to deflect very much. I think mine is a 0 - 200 amp range, so a single lamp might not have much of a noticable effect on it. You might need to add load, such as more lamps in parallel, or something that draws more amps.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
