Posted by pete 23 on November 18, 2009 at 18:27:51 from (173.87.147.73):
In Reply to: stearing on combine posted by lmbky on November 17, 2009 at 17:50:49:
I'm not a combine mechanic per se, but I did have to do the engine work and some hydraulic work on them. Hard to beat the 1460 all around. Depending on hydraulic system you have, original or later electric over hydraulics, there was considerable changes and alterations made in regard to the steering being jerky etc and I am sure an experienced combine mechanic could steer you in the right direction to correct it. I do not have service bulletin for combines but I know there were some addressing the problem. Far as leak, I'll assume it is coming out of steering shaft and a pretty easy fix.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
