Posted by ScottyHOMEy on November 23, 2009 at 13:38:18 from (70.105.226.116):
In Reply to: Spark Plug Wires posted by gary north of spokane on November 23, 2009 at 12:27:24:
1-3-4-2 is your correct order.
#1 in most often located at about 2 o'clock on the cap when viewed from the rear. Plug in clockwise from there.
It that doesn't get it, pull your #1 plug and turn the engine until you can feel the air forcing out the plug hole on the compression stroke. Make a mark on your distributor body where you think #1 ought to be and pull the cap to see if the rotor is coming up on that mark. If not, look it over and put #1 on the tower on the cap that the rotor is approaching and go from there.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
