Re: IH 2000 Loader on a 495
Posted by mkirsch on January 02, 2010 at 06:13:13 from (67.240.251.254):
In Reply to: IH 2000 Loader on a 495 posted by SCFarmer on January 01, 2010 at 16:28:28:
The front loader rails appear to just sit on the front brackets. Because the loader is securely attached to the axle it can't fall off.
What you need to do is get the loader situated in place on the tractor, and bolted to the rear axle. Then get some heavy steel plate and build a set of brackets to locate and support the front frame of the loader at the mounting pads on the front of the tractor.
The front brackets need to keep the loader from moving side-to-side, and need to hold it level.
Personally, I would figure out a way to bolt the front rail of the loader to those front brackets so it won't try to lift off when you push down or dig with the bucket.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
