I don't believe it because I understand how the system works, and what you describe equates to "cartoon physics."
Oil heats up faster when it's pumped under pressure. If you just hook a hose between the two ports, and tie the lever back, very little pressure is developed and very little heat is generated. The oil just blurps out the top hole and runs back in the bottom hole, or vice versa.
In order for your scheme to work, you'd need a restrictor in the hose. That's a fitting with a tiny hole through it instead of a full pipe. They make them in straight hose couplings, and elbows.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
