Use a hy guage to see how much pressure the pump is putting out. Also the seal in the pump mite be shot and hy fluid could be leaking into the crankcase. Your pump should be putting out 1000 under load. Your control valve could also be leaking. Many things to check .
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
