Posted by riverbend on January 21, 2010 at 06:59:41 from (208.160.33.198):
In Reply to: B engine block cracks posted by gurneejoe on January 20, 2010 at 20:02:55:
That's bad. Are there cracks between all the cylinders ?
I had a block welded that had cracks similar to the middle picture, that went between cylinders 2 and 3, and between 3 and 4. I looked for a couple years and could not come up with a good used block, and really wanted to use the tractor.
The spray welding cost me $12 per inch a few years ago. The surface of the block was machined and the sleeve recesses rebored. There was a big crack behind the carb too. The welding cost $288 and the machine work was $45 (IIRC).
The repair has held up so far and the cost was about the same as a used block. Welding worked for me. I'm not sure if brazing would be strong enough.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
