Re: IH 484 brake problem
Posted by 495man on January 21, 2010 at 13:36:49 from (24.137.106.3):
In Reply to: IH 484 brake problem posted by Brock,Chris on January 20, 2010 at 20:29:03:
Air getting in the brakes is a "common" problem.
Might just be something simple and bleed once and be done, or more complicated.....
If the rest of the tractor is "perfect" then fixing one brake might be worth it even if it ends up being a bigger job then a simple bleeding.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
