The B-414 has about 35 PTO HP and about 31 DB HP which would be the same on the 3414. I don't know how the shuttle transmission would hold up on heavy tillage work. Several different hydraulic pumps were available so I don't know how much hydraulic capacity this 3414 has, but, the 3414 was designed for loader/backhoe work so you would probably be in good shape for a backhoe. Worse case senario, you could add a front mounted pump for the backhoe. They were normally mounted with a 3012 or 3014 backhoe when ordered from the factory.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
