Posted by The tractor vet on February 18, 2010 at 13:01:20 from (75.19.124.251):
In Reply to: Installing a Clutch posted by Pete7 on February 18, 2010 at 10:04:02:
The idea of working on tractors is to make the job esier and the way i do it also reduces the risk of messing up a clutch disc when tryen to slide , you noticed i said SLIDE the two pieces back together and not force it with bolts . and since i am sorta lazy i can lay down and reach up in and bolt it together .and by having everythink bolted back together all the blocking spliting stands and jack stands are out of the road the floor is cleaned up and all that is left is bolting down the pressure plate and adjusting the clutch and T/A linkage .and out the door .
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
