Re: .060 bearings
Posted by Stew Holliday on February 23, 2010 at 06:19:57 from (68.231.6.108):
In Reply to: Re: .060 bearings posted by rustred on February 22, 2010 at 18:12:52:
Hey Guys,
I bought the tractor not running, took the pan off to find that some one overhauled the motor and the main middle cap was off, so I thought I would put in new mains only to find out after I had it miked that the mains were .060 under. The tractor has only 2900 hours on a working tach,also had the head checked was cracked had it fixed. So you think that bearing from a M will work? Or
should I get a new crank? Thanks Stew
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
