Posted by Griff NC on February 23, 2010 at 17:34:52 from (65.41.40.67):
I got it back together today . Tight steering , like it should be . I decided to fill steering box with grease , steering box shaft was pitted . I talked to the guys at the machine shop , we discussed using a speedi sleeve , at the cost of the sleeve and the extra machine work , I decided to just put in a grease fitting and pump it full. I packed all bearing as I put it back together . I changed all fluids , the strainer for the hydraulic system was stopped up starving pump for fluid , Screen had a small hole in it after I cleaned it up . I tried to sorder that spot closed , did not work had to make a trip to the Case dealer and buy a new strainer . Well if it ever dries out I am ready to plow . STEERING WORKS LIKE IT SHOULD ----
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
