Re: How much paint do I need to paint a Farmall super C
Posted by sflem849 on March 07, 2010 at 16:57:23 from (69.197.84.192):
In Reply to: How much paint do I need to paint a Farmall super C posted by David G on March 06, 2010 at 15:02:27:
Agricon said: (quoted from post at 17:52:28 03/07/10) Lastly, does the spray can version of the Case IH paints produce the same finish as normal paint with hardener does?
NO! It should produce the same color, but it is will not "lay down" as thick as "real" paint. My NAPA man sold paint for Martin-Seynor before buying his NAPA's and he has a little example body panel painted with real paint and rattle cans. You can barely scratch the real paint and the rattle can will scratch right off. He said it has to do with how many mils thick the paint is using each method and how they dry.
With all that said, if you are just going to rattle can little parts before assembly and use real paint on the majority of the machine you will be set.[/u]
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
