Posted by The tractor vet on March 17, 2010 at 07:58:41 from (75.19.124.251):
In Reply to: MD head torque posted by BruceS. on March 17, 2010 at 07:26:14:
They are torqued to 110-135Ft. Lbs. Now when i did them i always run a tap thru the nuts to chase the threads and a thread chaser over the threads on the studs to make sure that there were no burrs and that the nuts turned freely over the studs so that you got a good torque . Also i would put a light coat of Lubra plate or white grease on the stud threads . For the best results i would torque them down in three steps starting at around 65 Ft. lbs then 90-95 ft. lbs, then to the 130 135 and go back over the last setting three times starting from the center and working outward .
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
