You might want to consider something like this. This won't be cheap either. This is a W-400 being set up for suitcase weights.
That hole in the frame rail is where one of the frame weight bolts should pass through to the bolster. The bolster is not drilled. Apparently IH used the same frame rail on both the F-400 and W-400.
This post was edited by Wardner at 11:20:59 03/28/10 2 times.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
