Posted by Russ from MN on April 01, 2010 at 17:50:34 from (68.235.68.3):
In Reply to: flywheel question posted by jerry hakenwerth on April 01, 2010 at 06:41:05:
I am not familiar with a Farmall flywheel yet but when I was working as a millwright when I had something heavy and awkward I would take a couple of longer bolts and cut the heads off. One should be longer than the other so you only have to start one at a time. Some times I would cut screw driver slots in the end if they would not protrude, or if they do, grind flat spots. You can also make some marks ahead of time for proper indexing.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
