Posted by ryanwheelock on April 06, 2010 at 05:54:41 from (67.59.45.185):
1st question, how would you hook-up the christmas-tree valve to operate a 2 way cylinder for rear implements and still have my front-end loader control rod not pulled out all the time like most do with the 2-way valve. Some type of flow divider?
2nd question, years ago did farmers take a hydraulic cylinder and use it for multipe implements? I want to use 1 cylinder for a NH haybine and also on an Oliver disc as long as the stroke is the same and just pull the pins each time.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
