Johneich said: (quoted from post at 10:31:14 04/06/10) Hmm, tesmith, thats interesting, the level was checked full with the loader and rear lift in the down position, should they be raised when checking to see the oil flow out of the little hole on the left side of the transmission area?
John
Not sure, but I know that I cannot get the loader to full height unless I have a full sump. My 340 has power steering which may account for the extra oil need. The extension I was referring to raises the oil level about 2". When I do a filter change it takes about 12 gallons to top it off. I have no idea if this is the way it's supposed to work, but that's how it was when I got it.
Also, make sure you have the selectors on the valves set to either single or double acting (depending on your cylinder type). The clip that holds the selector in place on my bucket valve is gone, so it moves on me and causes the bucket to stop working until I move it back. Guess I should fix that someday...
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
