Posted by mkirsch on April 13, 2010 at 05:29:32 from (64.80.108.57):
In Reply to: looking for a cub posted by cheif on April 12, 2010 at 17:57:14:
cheif said: (quoted from post at 17:57:14 04/12/10) I know there is a lot of cubs configured with a belly mount mower. What's the problem; Power, no live power?
What people fail to keep in mind is that these tractors are up to 63 years old, and most of them are well used. There are a lot of Cubs out there that could really use some engine work to get them back up to snuff.
As long as the engine isn't worn out a Cub will handle a PROPERLY SET UP 59" deck no problem.
The second problem is people don't set up the decks correctly. The deck needs to be at least 1/2" higher in the rear than the front, or else you're cutting the grass TWICE. Considering that you're actually cutting almost 10 feet of grass with the deck pitched the wrong way, and the Cub is still doing it, that's amazing.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
