Re: How much torque for hydra-touch control valves?
Posted by Nebraska Kirk on April 23, 2010 at 08:15:24 from (207.91.4.199):
In Reply to: How much torque for hydra-touch control valves? posted by bkpigs on April 23, 2010 at 05:15:56:
The O-rings fit in a machined recess, so they will only smash so much. My hydra-touch manual does not list any torque specs for those bolts. When I reassembled my valves after replacing O-rings, I used an 8" long 3/8 drive ratchet and turned the bolts tight. Works fine so far, no leaks.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
