You could try the bolt busting technique, and try to get some heat onto the hub, to break up the rust just by the heating ad cooling, and use wht I talked about earlier about letting things cool enought o draw in more penetrant when it cools below the point that it simply evaporates it. With that much iron bonded to the hub to sink the heat away, I shouldn't think that you'd ruin the temper of the hub or its shaft with the heat.
From what you describe, my best suggestions are patience and persistence. Don't forget to rotate them so that you're beating on different spots. They will come apart.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
