Posted by ScottyHOMEy on May 06, 2010 at 20:03:49 from (70.105.252.192):
In Reply to: stuck governor posted by rustytenn on May 06, 2010 at 18:48:22:
You're on the right track, rusty. The governor is basically an empty cavty that gets all the lube int needs if the motor is run regularly, but can get crusted up and sticky from lack of use.
The control side, between the lever at the seat up to the fly weights, can be worked loose with the lever, but the other side, that drives the carb, can still be sticky. Start with a good cleaning all over, with special attention to the bushings on the carb side, and replace any parts necessary in the process (like that pesky thrust bearing around the center shaft) and give it a try.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
