Posted by Janicholson on May 23, 2010 at 19:48:22 from (64.61.211.40):
In Reply to: steering fluid posted by Treesa on May 23, 2010 at 16:15:36:
Andrew Z is correct. If it runs right out on the ground, Put in a grease fitting where the fill hole is, (adapt) and fill it with a substantial amount of grease. John Deer Corn Head grease, or Mobile1 synthetic chassis lube work well, and don't drain out. Fixing the seals is the other solution! Jim
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
